Problem with the immobilizer of a Peugeot
14 years 2 months before #21113 by manual-mecanica
Problem with the immobilizer of a Peugeot published by Manual-Mecanica
I have a Peugeot 206 year 2000 with 1.6 engine it seems that it is blocked does not give me food (voltage) towards the fuel pump, the injectors, the set of ignition coils. They told me that I could light it with the key that has no control but it was not someone who can give me help.
14 years 1 month before #21134 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with the immobilizer of a Peugeot
I had the same problem, I was, I bought the immobilizer install it and the problem ended, unless the pump first would be saved and the direct probation.
14 years 1 month before #21145 by manual-mecanica
Check that all the connectors of the switchboard and the round Ke is under the air filter are connected and in good condition it also checks the fuel feeding tubes there are times keth and it makes those good luck symptoms
14 years 1 month before #21475 by manual-mecanica
I already checked the system but if someone has the Peugeot 206 MP7.2 and I could facilitate them, I would appreciate it, I need the BSI diagram,
