Fiat Stilo 1.8 16V safety fault
14 years 2 months before #21110 by manual-mecanica
Fiat Stilo 1.8 16v security faults published by Manual-Mecanica
Good evening, someone could help me, I have a Fiat Stilo 1.8 16V that does not want to turn on the message of the living vehicle safety in Ecuador and here they only sold 3 Fiat Stil
14 years 1 month before #21143 by manual-mecanica
Manual-Mecanica Response on the Re: Safety A Fiat Stilo 1.8 16V
A lock comes out or that says code or safety breakdown first if I was repairing or doing something to the car verifies the land of the computer and verifies if there is no positive current in that land if it will never turn on
14 years 1 month before #21144 by manual-mecanica
or also see if the coil is running and if the gasoline pump turns on if none is missing a land or a earth cable is released
14 years 1 month before #21163 by manual-mecanica
Thank you brother, do you know that the control of opening the doors doesn't serve me either for me?
I will verify the earth any novelty, let me know thank you very much for the council
14 years 1 month before #21165 by manual-mecanica
It is for the same friend here in Venezuela there is fiat but if I am not mistaken that is 1.6 16v that is five but that is missing d or the earth is positive and while this positive will be blocked by the Code tries to remove the land from the computer then you put a direct of the battery and time you turn on
