Toyota Hilux problem
14 years 2 months before #21091 by manual-mecanica
Toyota Hilux problem posted by Manual-Mecanica
I have a toyota, I completely download the battery in minutes, floor the accelerator and the engine lowers its revolutions abruptly.
Could it be a current leak per alternator ??? It will be possible that after starting the engine, stopping it, starting the battery again?
14 years 2 months before #21093 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Toyota Hilux
Possible the current is being grounded is to verify ground connections
14 years 2 months before #21096 by manual-mecanica
It is easy to walk the vehicle and measures the load that the alternator throws, with the help of a tester, to measures that you accelerate the load must be greater not less, the other thing that can happen is that the battery is in cut or in very poor condition, it is unlikely that it is discharged immediately and that the residual load is layers of giving game, I suppose that you already check the state of the terminals and those things?
14 years 2 months before - 14 years 2 months before #21098 by manual-mecanica
It is true, you must check how much your alternator loads, when rpm upload the battery load voltage will
up Example
voltage in idle 14v
lights, radio, air conditioning, windshield clean 13.5V
Total difference 0.5v <1V
but never less than 13V if it is lower do the maintenance of your alternatorB) B) B) : Laugh: : Laugh: : Laugh:
Latest edition: 14 years 2 months before by .
14 years 2 months before - 14 years 2 months before #21099 by manual-mecanica
only battery land?
