Opel Monterey 3.1 of 94
17 years 4 months before #2096 by manual-mecanica
Opel Monterey 3.1 of 94 published by Manual-Mecanica
Hello, I have a small problem with thevehiculo, it is that when I turn on the attached air it does not rise from revolutions, before when the car put it, it increased with revolutions and now not, someone knows where the subject can come from, taking advantage of if someone knew how to tell me to serve a button that is next to climbing the electric antenna would make me a great favor.
Greetings and thank you very much.
17 years 4 months before #2105 by manual-mecanica
Manual-Mecanica Response on the Re: Opel Monterey 3.1 of 94
I have no idea of ​​the button, but the air conditioning I tell you.
That car carries a solenoid valve that opens the way to a small vacuum lung located in the injection pump, if it does not accelerate, you have to look if it comes running with the pressed button, if it opens or if it is stuck preventing the passage of the air from the lung to the vacuum pump, and finally you have to look if the empty lung itself that is in the injection pump has the perforated membrane.
It is no more that you also look at all the finite plastic tubes that pass through the engine, it is not going to be broken or loose and have the problem there.
All the best.
