I have an Ipanema
14 years 2 months before #20863 by manual-mecanica
I have an Ipanema published by Manual-Mecanica
Hello I have an ipanema and it is impassive I find the manual since I have an electrical problem the caul I cannot solve x the lack of the manual xq in my car I do not have the part where it explains so that they are fuse caoda and every relay of now thank you very much
14 years 2 months before #20887 by manual-mecanica
Manual-Mecanica Answer on the Re: I have an Ipanema
It is easier if you tell us what problem you have to see if we can help you, the fuses you can review them all with the help of a Tester and Lor relaxays are not many truth to be more than 4 or 5, anyway with the same tester you can check it.
14 years 2 months before #21029 by manual-mecanica
Hello, how about my problem is that the gasoline pump when I leave it all night stop
14 years 2 months before #21030 by manual-mecanica
14 years 2 months before #21035 by manual-mecanica
It begins by reviewing the connection behind the rifle, the cable may not be a good connection with the fuse and at the time of connecting and disconnecting consecutively until it comes to make contact the fuel pump running, otherwise check how much the fuel pump feed in the morning with a testter (12 volt) and contact given without doing anything in the fuse (more than anything not to disassemble the fuse holder). (12 volt) You must check whether or if the connection of the holder-fuses. More than anything this is a frequent problem of bad connection or damaged wiringB) B) , but nothing that the case of light is alarmed only that there is no naphtha pressure on the line (if you do not have tester, verify with another person (handmade) in this way, one in the steering wheel giving contact and the other in the pump, this will turn to the key (without starting the engine) and the other will listen to the noise of the pump (usually sounds like 3 5 seconds before starting) to verify that the pump works, if it works, it only remains to verify pressure on the gasoline line with a manometroB) B)
