Problems with the changes of a 200
14 years 2 months before #20598 by manual-mecanica
Friends, I have a Renault Twingo Year 2000 Mechanical five -speed box, and despite having changed the clut clutch you feel very good
thank you
14 years 1 month before #21683 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with the changes of a 200
Hello, I have the same problem, could you find a solution? Thank you so much!!!
Silvio
14 years 1 month before #21688 by manual-mecanica
What valve are you throwing?
14 years 1 month before #21708 by manual-mecanica
Hello thanks for answering, look, no idea what oil is we put, the mechanic and the lubricentrity told me it was good !!!
14 years 1 month before #21719 by manual-mecanica
Look corduroy you have to check the blade first of anything because if it does not enter 1,2,3 and 4y5 it is a blacker if it were croche or guala or bombin will not enter any check that the varillage does not go with game xq if I do not mistaken the blade of that car is with gua The Varillage and then see that it is your problem and you will solve it soon
