Express is a relay between the key and the start
14 years 3 months before #20280 by manual-mecanica
Hello everyone:
I have a Renault Express that does not start with the key. To start it I put a direct cable from the battery to start and work. I disarmed the key contacts and tried them with the tester and I think it works. Do you know if there is a reliable or fuse between the key and the donkey?
14 years 3 months before #20284 by manual-mecanica
It does not bring a starter, that does not mean that an additional one is added, I suggest that you follow the wiring that goes from the room to the engine has chips that usually sulfate the terminals the terminals
14 years 3 months before #20285 by manual-mecanica
thank you. I'm going to try
