Automatic Control Ruedas C4 Picaso
14 years 3 months before #20102 by manual-mecanica
Automatic Control Ruedas C4 Picaso published by Manual-Mecanica
Hello!
The problem is that it is indicating me in the picture, at every moment, that the pressure is bad, when the pressure is perfectly controlled.
How could the problem correct? Where does the sensors carry?
If you can there, I appreciate it. Thank you in advance.
All the best.
Campio
14 years 3 months before #20107 by manual-mecanica
Manual-Mecanica Response on the Re: Automatic Control Pressure Ries C4 Picaso
Good night, in these systems recommend deflating the tire totally and inflate it to the specified pressure, do this procedure three times in a row, then put the car to roll so that the sensors send a pressure signal, if the problem continues you must change the wheel inflation valve that presents the fault (the valves are the sensors)
14 years 3 months before #20135 by manual-mecanica
Thanks for your answer, I will take the test one of these.
If I get results, I communicate it to you.
Chao Until another day.
Campio
