Welcome to the companion forum, your problem looks like being caused by a badly made mass or by a short in a bulb.
This problem can have it in the car fuse box, in the instrument box, or in one of the rear pilots.
If you have a current problem in the same pilot, you go to notice for a characteristic \ "Fair of Lights \" when you step on the brake, or give the intermittent, (in addition to an abnormally fast flashing on one side) or when you put back.
If it is in the picture, you have to disassemble it to test the cable hoses because some dough is possible, or some cable is playing where it should not.
If in the case of not seeing anything in the hoses that reach the box, it would be necessary to look in the fuse box, where they take it many instruments of the car (including the brake lights and the ABS). Because there are also of the body masses and body masses and the cake can be there.
Greetings and I hope you don't give you many headaches.
