Focus Failure 2001
14 years 3 months before #19888 by manual-mecanica
Manual-Mecanica Answer on the Re: Failure in Focus 2001
Hi, putting together with the codes that throws you most likely that the injury of cylinder 3 this with ponddust problems or drip when it is closed. For that, you should take it out and take it to try, if you do not have the posivility of mounting it in a test bank of injectors. Note: The ideal would also be to take the engine compression and thus be able to rule out mechanical problems that can be coexisting with a failure in the fuel feed system greetings.
14 years 3 months before #19986 by manual-mecanica
how are you.
I had a very curious fault that the accelerated power
felt time as late. At the end of the accounts it was the damper of the cranpy damper had wear the wedge and as the crankshaft sensor carries it in the Damper, it delayed the ignition time
this fault was presisted in a focus.
You will be there for the failure.
From the injector it could also be. But sometimes there are several causes of the fault and we are looking for only one.
luck.
14 years 2 months before #20688 by manual-mecanica
The car that I am fixing is an automatic Fordour and the scanner marks the codes 0303 bad combustion in cylinder 3 and 0171 System too poor in Bank 1 already changes cables, spark plugs, coil and pump and continues with the fault. Do you think it is enough to wash the injectors? The same thing happens with the Focus loses power when accelerating but also marks the code 0708 High in the circuit of the transmission range sensor will these failures be linked or are they independent? And I can't find that sensor in which part of the box is
14 years 2 months before #20695 by manual-mecanica
Look that the Lambda Control it is good with a tester (preferably of the needle of those old) in the probe signal cable that at least about 10 signal cycles in 30 seconds if this is very slow, you want the zonda to be contaminated and for that reason it is sending a bad signal, it could also be that the dirty injectors were fixed the milliseconds of injection in relief if they are normal or very high.
14 years 2 months before #20716 by manual-mecanica
Thanks for the tip, I already burst the injectors and are injecting the amount of gasoline well, does it have something to do with the temperature or oxygen sensors? The crazy pulley changed him for a long time, could it be that time is wrong but it is automatic?
