Hello everyone if someone can help me
14 years 3 months before #19626 by manual-mecanica
Hello everyone if someone can help me published by Manual-Mecanica
Hello, I would appreciate if someone could give me information regarding an injection BBA of a L 200 the issue is that although it turns it does not send oil to the injectors, check the electro stop valve and recovery food of the battery and acts but despite having oil and the election open the pump does not raise any precion or flow. What can it be?
14 years 3 months before #19642 by manual-mecanica
Manual-Mecanica Answer on the Re: Hello everyone if someone can help me
Greetings Zatara, in your comment you do not specify if you already replaced the fuel filter, if it is saturated with dirt the fuel will not properly flow to the injection pump, it also verifies that the transfer pump is supplying enough fluid. of food, if you do not have supply pressure, the injection pump is not appropriate and does not inject. You must also take into account the physical state of the hoses that are not cracked. After verifying all this and if everything is fine then your injection pump could be damaged and will require laboratory service to re-regulate it. Greetings and luck
