Fag in my Ford Explorer ...
14 years 3 months before #19610 by manual-mecanica
Fag in my Ford Explorer ... Published by Manual-Mecanica
First of all, a coordial greeting, in the last month I have had a fault in my Ford Explorer truck 2001 Dos doors trash doors, the issue is that the scanner does not detect the fault, the fuel pump has been changed 3 times in different workshops, the fuel pump has been cleaned at least twice by the three workshops that I have visited the injectors with ultrasound siystem! and the results are the same and the mechanics do not get possible explanation .. The truck has no strength and when accelerating it stays as a drowned it does not accelerate, already check the possibility that the exhaust tube was covered and it is fine, I completely check the fuel lines and have no type of obstruction or break have they been able to solve the problem .. does anyone have any idea? Background: Everything began after the gas tank by a loose hose was filled with clay with water. When measuring the pressure of gasoline the pressure is 60libers.
14 years 3 months before #19613 by manual-mecanica
Manual-Mecanica Answer on the Re: Falla in my Ford Explorer ...
Start by checking the hoses where the fuel carries to the allomejor engine is covered with mud .....
14 years 3 months before #19614 by manual-mecanica
Hello, a question, is a bomb aphorador? or just a loafer and the pump apart? If it is a bomb a pump look well the filter that carries for the pump, if you do not look at the topic of pipes that something will be obstructing
14 years 3 months before #20036 by manual-mecanica
I do not understand much about a loafer, ... but the truth that apparently is that he uses a gasoline pressure regulator after the one commonly called by a bar They sell it alone if not with the full bomb group and floating and good so far I am not sure if that is the fault but when trying it ..
