Hello everyone again, well, then I clarify the breakdown so that if it happens to someone who can solve it.
It was tried to regenerate the FAP, according to those of Renault, at 80km/h 20min despite being a gasoline I think it does not carry fap, the question is that it was not fixed. And it may be that the cayalizer has touched it.
He changed the oil and spark plugs (the originals, he also touched him) did not arrange the same pull and low power.
The diagnostic computer said that the cylinder No. 1Tenia combustion failure, and when removing the spark plugs to change them I saw that the cylinder nº1 and nº4 were burning badly, the very black spark plugs.
What made me think even more than the coil, when the part of these two cylinders was double (they are couples cylinders), because I had some intermittent failure because I was not accused only when I needed to give more current.
The next thing was to look for a "non -original" coil and try, the car change totally, the problem is corrected as before and does not pull.
So this is what I can tell you, by the way, the Beru coil, it seems well.
Thank you very much to all who have contributed your comment.
