EGR valve can be removed
14 years 4 months before #19294 by manual-mecanica
published by Manual-Mecanica can be deleted
Hello,
here is a question to have if possible, well what I am going to delete the EGR valve from a 1.9 TDI 130CV.
Greetings and thanks beforehand
14 years 4 months before #19387 by manual-mecanica
Manual-Mecanica Response on the Re: EGR valve can be removed
Yes, there are electronic modulas that connect between the caudalimetro of the car, connector of the EGR and the PAP engine that carry some cars the gas butterfly, and you can annul you that you do not have error in the switchboard. Another way is to experimenting in an Astra Cdti 150, and I have almost achieved it, it is to make a metal piece that clips the exhaust gases, but it takes clean air when the EGR opens, I have it like that and it does not give error in the painting.
14 years 4 months before #19391 by manual-mecanica
Very interesting laundress. have if I deepen more in this topic of the EGR valve. I want to get that there can be completely eliminated.
Health and thanks for the comment.
14 years 4 months before #19393 by manual-mecanica
Tapas the pipe that sends escape gases to the admission and voila !!
14 years 4 months before #19455 by manual-mecanica
Bujia82 wrote: tapas the pipe that sends escape gases to the admission and voila !!
I had thought that but I don't know if I would give any problem or error.
How everything is controlled by the ECU.
