Hello I have a Fiat Spazio 147 Model 89, today I began to lose oil inside it leads it to a mechanic because it also left black smoke x the escape pipe and I thought it had to regulate it but he told me that everything was for the oil, that something of the rings was broken and that the oil did not reach the engine and that is why he lost oil and came out black smoke, that I must stop the car and fix that but I will fix that.
Hi Nico, did you check that the engine discharge is well uncovered? When covering begins to lose oil anywhere because the gases that are generated inside the carter have to leave and raise pressure, look at that before disarming, tell us how you go, greetings.
