How friends I hope you can help I have a problem with the refrigeration system of a Peugeot Parner the problem is that the electro fans do not light and when the temperature of the manometro arrives at 90 degrees the refrigerant liquid begins to leave by the renovation of the refrigerant but I believe that the temperature it gives me in the manometro is not real since the thermostat at the 83 degre that in the manometro marks 60 degrees centigrados.
Hi Chrisdav87. For your safety, it measures the temperature with a mechanical apparatus and compares, the thermostat must begin to open to the 75º and that temperature starts the fan, at the 80-85º the temperature is stopped being 70º. Luck. Miguel.
If the electros do not start, they can be the relays or the temperature bulb, which has two different one is for the meter and one for the electros, at least in a diesel that it had is like that.
