Alternator Renault Twingo Year 94
14 years 5 months before #18547 by manual-mecanica
Alternator Renault Twingo Year 94 published by Manual-Mecanica
Hello! I am Adriana, I am new and I do not have much experience in forums
14 years 5 months before #18555 by manual-mecanica
Manual-Mecanica Response on the Re: Alternator Renault Twingo Year 94
Marelli brand CG33211.70 A/V/RPM 50/13.5/3000, to give you more detail you would have to say the engine acronyms
14 years 5 months before #18565 by manual-mecanica
Thank you very much!
14 years 5 months before #18573 by manual-mecanica
Hello, you will see for the theme of the carra and amperaje you will not have projects. Better! Verify the position of the anchors greetings and luck
14 years 5 months before #18579 by manual-mecanica
Well ... now I am a little lost ... the spoiled alternator is still set up in the car ... the price that has given me in Bosch compatible with the broken one is very expensive, he had found it was cheaper but it must be that it is not worth .... The Q I have is a Magneti Marelli ... I'm going crazy .... Well thank you very much !!!!!
