ELANTRA 96 TIRONEA
14 years 5 months before #18476 by manual-mecanica
ELANTRA 96 TIRONEA Published by Manual-Mecanica
Hello, I have an Elantra 1996 1.8 and it throws me, that is, as the engine loses strength, one goes calm and suddenly loses speed abruptly and quickly returns to the speed that carried the strange one is that it does not always do it sometimes, the account turns itself does not regulate how it would Half tank always up, I have put the liquids that they recommend for injector cleaning, I have made clean the injectors, that is, everything ...
14 years 5 months before #18482 by manual-mecanica
Manual-Mecanica Response on the Re: Elantra 96 ​​Tironea
Hello, you can see several things among them I would observe the theme of the auxiliary straps in case you were taken by the alternator or a/c etc. Another could be a coil that when heated is opened as a primary greetings
14 years 5 months before #18488 by manual-mecanica
Well depending on the mileage that you have from the last one you see that you repaired the engine if you repaired it and if you have a catalogor you may notice that when the catalogor stops solving gases,
theory can
be electrical problems already mentioned by our colleague "chick", it could be the computer also
makes me something similar to the Fiat becoming the drunk ever to look at it, accelerator cable (including the acting springs) and unfortunately I can't think of anything when I can think of something else I warn you
greetings I hope it has been helpful
