the marches enter my megane but it does not
14 years 5 months before #18543 by manual-mecanica
It is impossible to change it 10 months ago and the car has not had mistreatment (in ten months and in normal conditions a clutch should not be broken?
14 years 5 months before #18546 by manual-mecanica
Greetings, I am also new here but I have a little time working with vehicles ...
well if you already check the arrows, transmission axes etc ... and your case is that the marches enter but the car does not roll; it is very likely that the clutch clutch disk is resurrected that is to say there is no good friction and it is possibly worn out or in its abse Weake.The clutch system dam ..., it is not re -elevant when you place Very personal 10 months is something for a cluth system ... Check the system, you have to disassemble to verify how the 3 (almost sympre unless it is multidiscus) mechanical elements of the clutch system ... Good luck!
14 years 5 months before #18566 by manual-mecanica
Greetings colleagues! Today and started to disassemble the car, the whole lifted from the nose, I have fallen it and assured that the right showers were (it will not be that I fall on top) and hands to work, I have disassembled the hose solving them of the shock absorber of the round of the bottom and the direction, then I put to remove palieres (or as you call the arrows) and to my surprise. of metal and a washer of the same size of about 70mmde circumference, which was split and out of a grim Another, I tell him that and I ask him that if that is why the car does not go even if the speeds enter, he tells me yes !!!!!!!: Laugh: that this washer and that clip is what endures in contact with the planetarium of the differential and that if it comes out stopped and does as if we lift it on one side ... it does not go!
14 years 5 months before #18680 by manual-mecanica
Hello greetings I had a problem similar to a 306 -2007 applied the speed or driver and had no traction, revised the tips of the arrows side box input with the differential and it turns Copilot side I hope it helps you.
14 years 5 months before #18708 by manual-mecanica
Check the perhaps transmission of breaks into the main pinion and that is why it does not transmit torque rises a wheel put in 5th or 4th and rotates the wheel if it is that it moves the engine is fine but if it goes in band it is a question of the transmission
