Hello everyone!!!
Benas Before I have a problem with my car, it's a Plymouth Breeze 4 cylinos 2.0. Do not turn on, I go march and nothing. Check the valve that has the flute of the injectors and leaves only air. proceeded to review the fuses and are ok.
Apply a jet of gasoline in the air and the engine turns it off 5 minutes working and works only that at 2000rpm it is very accelerated, I turn it off and I want to turn it on again and nothing presents the fault again as a lack of gasoline, there is no pressure on the flute of the injectors.
Proseci to lower the tank to check the gasoline pump. The disassembly and supplies by putting direct current to the pump and has a very good pressure to cover it with a finger and the run is strong.
This is where I roll up and I don't know what to do. I would appreciate a lot to guide me about it.
Will it be the pump?
Will it be the food lines?
Will it be the electrical system?
Will it be a valve sensor or something?
Any suggestion and help are accepted that they want to give me. I will thank you very much !!!
