DLC Hiunday Galloper 99
14 years 10 months before #15242 by manual-mecanica
DLC Hiunday Galloper 99 published by Manual-Mecanica
Good compis, I need to know if someone has an idea where horns brings the DLC the Galloper Exc v6 gasoline of 99, I almost put it up up and I do not find it !!!! please a cable that someone throws me ... thanks
14 years 10 months before #15277 by manual-mecanica
Manual-Mecanica Response on the Re: DLC Hiunday Galloper 99
Sorry but I don't know what you mean with DLC, if you dissolve your function you want to help you.
14 years 10 months before #15472 by manual-mecanica
Good compi, the DLC is the Data Link Connector, it is the plug to hit the scanner and I cannot find it, if someone gives me a little hand ...... Thank you !!!!
13 years 11 months before #23885 by manual-mecanica
Look I have the Galloper Diesel, and the DLC is on the right side (interior) in the part where the air comes out to the feet, in that same part is the ECU.
Luck
