Cavallier injectors affination
14 years 10 months before #15004 by manual-mecanica
Cavallier injectors refinement published by Manual-Mecanica
Good morning cosideizing that this forum is great I expose my problem, you will see my Cavallier 2002 but I listen very accelerated as refinement the acceleration of this engine.
Thank you
14 years 10 months before #15026 by manual-mecanica
Manual-Mecanica Response on the subject Re: Cavallier injectors affination
hello.
How do you ask what is called accelerated? How many rpm do you mark your instrument? And in what working conditions does it occur? The acceleration in any case controls the computer in idle and with load.
14 years 10 months before #15047 by manual-mecanica
Hojo that the Cavalier can make a small shape of adjustment by means
14 years 5 months before #18428 by manual-mecanica
Thank you very much for your advice, the engine matches quite what happens that it caby rings, vila bearings, and cylinder head maintenance, at the beginning the engine revolutions were heard strong however the instrument shows the medication of the engine is parkin of 1000 rpm that is normal I suppose I.
