My Neon ´97 goes out
17 years 10 months before #1478 by manual-mecanica
My Neon ´97 is off published by Manual-Mecanica
: twisted: I such atodos ...
well I hope someone can help me with my neon ´97
what happens there are times that in the morning that I turn on the revolutions fall and go out, but it does not always happen, there are times that if it turns on very well and everything, but alcola Climate, revolutions fall when the speed goes down, all this happens when the speed goes down, the PCV valve already disconnects and it is marching very well but now I feel it as it revolutionizes slower.
Could someone help me?
THANK YOU.
Pako Gzz.
17 years 10 months before #1483 by manual-mecanica
Manual-Mecanica response on the re: my neon ´97 is turned off
It looks like it is an admission air intake. You have not commented if the fault light is turned on, which would be very important, but I think your problem is that the engine aspires air without the switchboard finding out. Well because you have a bad meter of air mass of air or MAP sensor (Air Flow End or Mainfold Absolute Pressure) or because the air between some escape in the admission collectors.
To check this it is very easy, disassemble the air filter and tapas the tube with a seal. Then you do the same with the exhaust and for either of the two tubes (the admission or exhaust) you put pressure air, then spray soapy water on the admission multiple and if bubbles appear somewhere they will reveal you the air leak. Do not exceed 0.5 pressure bar.
If you give the postéalo fault here ok?
All the best.
17 years 10 months before #1486 by manual-mecanica
Because you don't make a computer review yourself.
17 years 8 months before #1709 by manual-mecanica
Look at the gasoline pump, if it is originally the bubble is filled with bubbles and stop, change it but by the original or the high for the Magnetic Marelli because the cheap trout will leave you lying on any side without warning you.
17 years 5 months before #1919 by manual-mecanica
Good, I have the same problem posed my automatic neon 98, in the morning when I turn it on sometimes it loses revolution and turns off other times not, and in some semaphore or a tail when the speed lowers the light of Ckeck Enginee is turned on and the battery light sometimes accelerates and does not go out but sometimes it accelerates the same goes out! I live in a pirate city that does not have a mechanic that really knows of Esots Cars!
E involved the computer and only throw an error with an injector but check them and nothing remains the same! Change the filters to gasoline and the same, it may be!
I hope you can help me and gone to mechanics and mechanics and I have not been able to solve the problem!
