"Check" light on the board
14 years 11 months before #14590 by manual-mecanica
Light "check" on the board published by Manual-Mecanica
Well friends, I don't know if it exests any similar topic, but I open this thread to be able to discuss this subject, in my life I have only had two cars, a mitsubishi colt year 91 and currently a Kia Spectra or Cerato according to me have told me and I do not Car and at the present time until a few weeks ago I got it on me but I do not remember at this time the error code that Mostero el Scaner, but actually the issue is to know in general terms because this frequent and annoying failure is activated, general causes, in reality I am not a mechanic, I am an informatical, my brother if it is a mechanic and I can certainly be able to move some tips that you could give me, thank you before. :)
14 years 11 months before #14593 by manual-mecanica
Manual-Mecanica Answer on the Re: "check" light on the board
Aver ndiaz, the light of Check-Engine is turned on to reveal the preciousness of some failure in the fuel injection system, this can be a large sea of ​​factors, the scanner gives you an indication of where to look for although it may not be right, it is unveiled attentive to the system to be able to perform some repair, depending on the vehicle's brand, it can be a lime. Scaner, if you have the code we can help you, if you do not have it enough to tell us what the code said, that is, oxygen sensor, of tenneath, IAC valve, TPS sensor, etc. You can also inform you of a rich or poor product of a bad combination according to an air leakage either by a scarce or an ecsse ecsse, this does not necessarily have to do with a sensor, but avitually if it is a fault of any, digos that makes, how much you spend or some more details to help you.
14 years 11 months before #14604 by manual-mecanica
If your mobility does not fail, they can be of secondary sensors such as detonation sensor, canister valves, O2 sensor, o2 sensor of the catalogor, (and if failure they can be a maf sensor, TPS, phase sensor ..
14 years 11 months before #14637 by manual-mecanica
Thank you for your prompt friends, the truth a few days ago they put the Scaner but they did not give me any information, rather it was not me who took it, but well, I will return to scare it, with respect to some indication the only thing that I have noticed is that the escape sounds strange, well I will see the fuel consumption because I have not noticed anything else, but with that list They said that the battery will disconnect to restart the computer, I will do that and then I give you more information, thanks again.
14 years 11 months before #14762 by manual-mecanica
Friends finally carry it and place the Scaner and it turns out to be the oxygen sensor, I hope I don't know anything else since the escape sounds its little, also if I have noticed that the fuel conceuming is a little greater, will it be for that reason?
