LEAVE ELECTRIC CRISTAL FOCUS 2005, 2.00 L
8 years 2 months before #52136 by manual-mecanica
LEVE FOCUS ELECTRIC CRISIS 2005, 2.00 L Published by Manual-Mecanica
Hello friends. The left back door of my focus has fallen. I removed the panel and observed that the plastic support that the glass supports on the slide is broken in his guides, which causes the glass to cross inside the door. In addition, for that fault, I suppose, the cable that allows the movement of the glass is tangled. As I do not know the operation of the system I do not know how to correctly locate the cable in its original position. Please, I need to advise me, if the plastic glass support is achieved as a replacement and the shape, if possible, to correctly put the cable on the motor reel, without taking out the entire equipment. Any suggestion to respect will be well received. Greetings and thanks.
8 years 2 months before #52142 by manual-mecanica
Manual-Mecanica response on the topic Levanta Cristal Focus 2005, 2.00 L
The machines repair them, it is not usually very expensive
