Hello good morning I have a problem with a Peugeot Boxer 2.2 HDI year 2010. It does not start. If you turn the engine. If you make you self -arranque (Ether) if it starts and until I take contact you keep up without failing. But if the stop stall with normal temperature does not start again. Some could help me thanks a greeting
Hello, check the high pressure pump also a main blue relay that is in the main engine compartment this can sometimes be wet and cause various failures. Is the check witness turned on? Is there water in the fuel filter? or mix of another fuel other than diesel? greetings
