Suzuki Gs 500 motorcycle
8 years 5 months before #51861 by manual-mecanica
Suzuki GS 500 motorcycle published by Manual-Mecanica
For speed lovers, and especially motorcycles, the Suzuki brand is synonymous with quality and a guarantee of good design and durability. With more than 50 years in the market, Suzuki ventures and advances more and more in the market of motor vehicles. On this occasion we will review the advantages of the Suzuki GS500 F Model 2005 motorcycle so that you take them into account if you are thinking of buying this motorcycle of the tourism line with all the support of the Suzuki brand:
The S500 F motorcycle has a displacement of 489.0 cc. It allows the fair amount of fuel to be exploited, without being a small capacity, it gives it enough power to feel the flight without becoming too heavy as tourism of other competing brands. It has a power of 39 kW (52 hp), gives 9200 rpm
Its 4 -stroke engine gives the necessary power in any condition, combined with two cylinders that balance this power and at the same time fuel consumption. It has a BSR 34 mm carburetor of very good quality that prevents the motorcycle from drowning, that you have a problem to turn on the motorcycle or that it takes that annoying white smoke.
It has CDI electronic ignition that avoids wear due to the lack of cam, does not have to open and close mechanical pieces, such as platinums for example. The multidiscus clutch submerged in oil bath, allows GS 500 F to absorb the heating that causes friction, which is distributed among several discs.
The double aluminum beam chassis created by Suzuki especially for sports motorcycles was a watershed in the industry and in the market, it gives the motorcycle an extreme rigidity and at the same time it is totally light, protecting the engine significantly without making the motorcycle heavy. It has disc brakes, both front and rear, which make a more dosed and not so abrupt braking, in addition to the ease of changing the brake pads and lower temperature of them.
A disadvantage of this model, as well as any motorcycle of this brand is that, although, it is one of the most important in the world, that quality is reflected in the cost of the motorcycle and the maintenance of it.
The Suzuki GS500 F motorcycle is an excellent option for connoisseurs. I acquired this motorcycle at the classified ads site Vivanuncios in Mexico (Nuevo León) And the purchase was excellent, I valued all the possibilities and I decided on it, it has been very good and maintaining it does not seem expensive, on the contrary, it is yielding quite well.
I hope the post is served.
Greetings.
