Opel Vectra failure
11 years 5 months before #45154 by manual-mecanica
Opel Vectra failure published by Manual-Mecanica
Hello friends, I have a vertra of the year 97 I ignite a yellow light in the picture an engine with a ray inside I do not know what it is because I do not have the instruction manual the car has run out of strength and I do not pull well you would know what I have already cleaned the agra valve and it remains the same if you could help me I would appreciate it.
11 years 5 months before #45155 by manual-mecanica
Manual-Mecanica Answer on the subject Opel Vectra
That lightless light that you have a problem and you have
to make a diagnosis to know the problem ok
11 years 5 months before #45156 by manual-mecanica
In a problem similar to yours, this was a 19dth vectra, it turned out that it did not throw because the turbo did not enter, it was a matter of an electrovalve that commands this, but in your case, you should look to make it a diagnosis, as the fellow Minge advises you. Greetings!!
