battery or contact key?
11 years 5 months before #45111 by manual-mecanica
battery or contact key? Posted by manual-mecanica
Hello, how, I have a problem with my vivaro, from time to time especially when I give the key to start it sounds a click on the start -up but Nosé moves the engine, the funny thing is that I first put it a little, nothing moves the van a little and with the contact key in the position of starting immediately the start -up begins to work, is it as if it is blocked.
11 years 5 months before #45112 by manual-mecanica
Manual-Mecanica response on the battery or contact key?
Hello, check brothers of the starter engine ... they will take spent. Revisa the engine when you remove it to see how the axis caps are going
11 years 5 months before #45116 by manual-mecanica
If I tell you the truth, I have never repaired a start -up, for 100 euros you have it new, but we would like to know how it is done. . . thank you
11 years 5 months before #45117 by manual-mecanica
Disassemble the starter engine, the rear cover of this, there will be the brushes, you will have to ask the price first, because they are faces ... When they tell you the price you will value if you get better going to scratch, but before buying it, you should look at this to see how you have them, it is not that they are equally gassed. The change of brushes is simple, just that you will have to give "Maña" to push all the docks at the same time. Greetings!!
