Hello guys. I tell you this hiunday I arrive at the workshop with this problem. They had changed: coils, even the new ECU. The truth is that I have doubts with the ignition module I do not know if they changed it, the owner does not know either.
I have tried everywhere, I doubt that it is a cut cable, they are not deteriorated, the 2 injectors do not reach the same cylinders either spark either. We shine and throw problem with the coil, but it is new. inverted the connection of the coil and spark arrives in those cylinders and also a signal to the injectors. I had not mentioned that part but with the 2 -cylinder problem. Friends I would like to know if someone has happened to someone or a specific manual for this model and be able to diagnose the fault. Well, if I find the problem, I will undoubtedly comment that it has not been easy. greetings. :
