Hi Jamoza, I don't know if I will carry another electria transfer pump in deposit (make sure) and see if it works. If not, you have any air intake in the aspiration-bomb aspiration pipe, which prevents the diesel from reaching the pump, as it returns to behind. It may also be that you need to purge the air that the pump has opening the injector hills and turning the engine until the "fuel" comes out; after tightening, try the start to see .. greetings
