Starting problems with a pointer
11 years 6 months before #44329 by manual-mecanica
Starting problems with a pointer published by Manual-Mecanica
Someone who can help me, I have problems with a 2003 model pointer model, the crankshaft is changed, but it brings crankshaft sensor, it placed their respective brands but the car does not start several times and apparently it is in time, the car does not spark in cylinders 2 and 3, there are injection pulses in the 4 cylinders, the stine sensor is already changed the tooth wheel and the coil.
If someone could guide me where to look for
please
11 years 6 months before #44347 by manual-mecanica
Manual-Mecanica Response on the topic Start problems with a Pointer
Hi Saules00 ", I do not know that car, but if the crankshaft sensor is very separate, it does not induce and does not give a signal, check the" entrehierro "if it is adjustable and approximate everything you can but without rubbing with the crown, look at the old sensor as far correct
11 years 6 months before #44385 by manual-mecanica
you synchronized camshaft, intermediate tree and crankshaft because if you synchronize the intermediate tree will not start you
11 years 6 months before #44398 by manual-mecanica
Hello, is the coil type coil for ??? Check the cylinder switch signal 2 and 3 ....
