VOLKSWAGEN CADDY LOCA CODE 1996
11 years 6 months before #44232 by manual-mecanica
Volkswagen Caddy 1996 Key Code published by Manual-Mecanica
Hello Foreos Friends. I have acquired an old caddy of 1996. It has no centralized closure or windows or anything. It has two keys, but one when using it, starts the van and stops. I suppose it will be the immobilizer. The other is going well. I would like to know if this key can be encoded from control panel with some trick, so as not to connect the computer (if you have connection taking). When I enter the 1stllave, I take it out, I put the 2nd key without coding and works. But when I stop the van and take it out of the contact, again it is devoted. Thank you very much for the possible suggestions.
11 years 6 months before #44242 by manual-mecanica
Manual-Mecanica Response on the topic Volkswagen Caddy 1996
Hello, it is not that it is unprotected, open the key of the key to see if it carries the chip or transponder, to the same is or is from another key. May I know, you can't program like this without more, but try to contact her, without trying, a minute, then take it out and wait about thirty seconds and put it again to see if it starts ... Tell us to see, but I don't think. You have to use the famous vag-com "el"
