Hyundai Matrix 1.5 CRDI problems, 2004
11 years 6 months before - 11 years 6 months before #44145 by manual-mecanica
Hyundai Matrix 1.5 CRDI problems, 2004 published by Manual-Mecanica
Hi, I'm from Antofagastas, I have a Hyundai Matrix 1.5 CRDI with 210000 km, I have changed spark plugs, injectors, valves, rings, fuel pressure censor. And the car is fine until one day it went out and I did not turn on anymore, it takes it to a mechanic managed to turn it on and it remains with pulls and emitting a lot of smoke, and the accelerator does not funeate, someone knows some data of the problem,
Last edition: 11 years 6 months before by .
11 years 6 months before #44189 by manual-mecanica
Manual-Mecanica Response on the subject Hyundai Matrix 1.5 CRDI, year 2004
Because of the Hel smoke theme, I do not know if it is oil, or a crop in a cylinder for a segment ... it measures compressions, if the smoke smells like gas, it goes pump and you have to look at Distribution Distribution, Pump Pump, then in the advance electrovalvula pump itself, then collector's pedal collector, but the first thing to look at is the crankshaft collector.
