The transmission hit by putting maximum change 2004
11 years 7 months before #44011 by manual-mecanica
The transmission hit when putting Maxima 2004 published by Manual-Mecanica
Someone can help me with this problem,
the transmission Aut. Of a maximum 2004, 3.5l engine
hit when it is direct (it does not always happen), or also when I directly do not advance well, it lacks strength, the and tried to get manual and melted and melted me marks me 5 speed when starting, I have to turn off the car and turn it on again and then it works well. When I bought it, they told me that the transmission had changed because the previous one was damaged
11 years 7 months before #44012 by manual-mecanica
Manual-Mecanica response on the subject The transmission hit by putting Maxima 2004 change
Good night, you need to run if automatic transmission is fine at the oil level, then check if your motor supports are not so damaged as to see if it is not a cause of false contact.
