Motor change from a Bertone
11 years 7 months before #43923 by manual-mecanica
Motor change of a Bertone published by Manual-Mecanica
I have an Astra G Coupe with 2.2 gasoline engine, which I get a vila for the carter, which forces me to change the engine, you could tell me if the Kadett GSI U engine of the Astra GSI possesses the same anchors to the engine as the vertone.
Thank you very much for the attention
11 years 7 months before #43961 by manual-mecanica
Manual-Mecanica Answer on the topic Motor Change of a Bertone
Hello, I feel your fault ... Kadett-opan if it is the C20XE I do not think it is worth you because the racks are much older, in addition to the gearbox, transmissions ... after power, this isv ... Centrality and its wiring, in short, a move. I would try to look for a block, or engine you had, luck
11 years 7 months before #43963 by manual-mecanica
I think the best thing you can do is buy the motor block for your car, there is a good second -hand market, Lucky uncle.
