Put Motor Bosch Bonba F8q Renault Exp
12 years 6 months before #39031 by manual-mecanica
Bonba Bosch Tuna de Motor F8q Renault Exp published by Manual-Mecanica
Le Canbie The engine of a Renault Express carried the type F8q 860 with with bosch injection pump and adjustable bonba pulley.
I replaced it with an equal f8q type engine but it was 640 mounted on Renault 19.
When it comes to mounting this 640 engine in the Express I changed the Lucas pump that I was carrying for the Bosch pump, when it comes to mounting the distribution I put the strain rallas that coincided with the points of the pulleys.
When it comes to starting it, it costs him a lot if I accelerate it while trying to start it, after a good time it starts me, but with a lot of smoke.
I think I have the bonba out.
If someone could confirm it and give me advice or solutions. thank you
12 years 4 months before #40522 by manual-mecanica
Manual-Mecanica Answer on the topic Bonba Bosch of Motor F8q Renault Exp
Go ahead the injector a tooth and test.
11 years 6 months before #44234 by manual-mecanica
Hello, as the first measure, the crankshaft and the camshaft are ready.
11 years 6 months before #44236 by manual-mecanica
Hello, apart from all this, I think that both pumps have a different progress draft point, and injectors with different flows ... Lower a manual of both engines and compare draft values, there are described the draft methods with comparator and its palpator, look to see
