Hello colleagues, I agree with Jairo, I have had that problem and several vehicles of diffent brands with the temperature sensor, I need to ask you a question that is fundamental and always presents when said sensor is bothering, when the engine is cold, I mean when you start it for the first time in the morning immediately? The engine drowns in fuel and is definitely the temperature sensor, I can recommend that you use and make a small trick, before buying the sensor: you baffle the sensor and in the terminals or connector legs (plug), you put a resistance that is red, red, red without impotenting the colr of the ends, that deceives the computer made it believe that the engine is already in temperature of the function. Determine measuring the resistance of the new sensor being heated in water.
Att.jorge Diaz de Panama
