Hello everyone, I have recently seen your messages. The car does not yield any check Engine, so you do not specify the problem that occurs, I need help with some manual or software please, greetings from Iquique I Region, Chile.
Hello , I had the same problem and it was only the fuel economizer sensor found on the Embreague pedal. You stole it thoroughly and you will see a square box with a pirulo that comes out of it, take the pirulo and move it if it is hard or soft when pressing, if it is soft it is that you break the spring you just have to change the spring value +- $ 2500 full sensor $ 18000.
Hello good to all, would you have the manual of the owner of the Hyundai Accent 1.5 CRDI 3 doors? If you have it and do me the favor of uploading it I would be greatly grateful, thank you and I hope to answer .
