MONTERO IO 2.0 GDI, Lack of Power and Tugs
11 years 11 months before #44577 by manual-mecanica
Montero Io 2.0 GDI, Lack of power and pulls published by Manual-Mecanica
Hello, I have a montero/straw IO 2.0 GDI, with lack of power and pulls when power is demanded, in eco -failed driving system´ ...
filter, changing spark plugs
, and the pipe of the coil of the 4th cylinder that was in poor condition, but it remains practically the same .... engine falls down. I have asked in Mitsubishi and do not know very well, they tell me that they are good engines until they begin to give problems, they are apparently quite special.
Please I need some help, I don't know what can happen to you, I wait for your help, thank you very much.
11 years 11 months before #44579 by manual-mecanica
Manual-Mecanica response on the Montero Io 2.0 GDI, lack of power and pulls
because the failure you describe to me is typical of lack of gasoline. Very covered the filter or the pump with low pressure. If when checking the above it is fine, another point would be the TPS or if it has a check that is not covered.
11 years 11 months before #44598 by manual-mecanica
Hello everyone, I totally agree on Armando, a gasoline engine with direct injection is very sensitive to a fuel feed failure, when the engine is subject to the engine emits a hoarse sound and fails to increase the revolutions. All this assuming that Chek Engine is off when you use the engine. Greetings to all.
