Picasso 1.8 16V Power Lost Motor Failure
11 years 11 months before #44543 by manual-mecanica
Picasso 1.8 16V Motor Motor Fall Published by Manual-Mecanica
Hello, I have a problem of my gasoline picasso 1.8 16V I get the motor failure message and the revolutions are lowered and Buelbo to start and already works but the problem is increasingly repetitive Connected, someone knows why or that the cable will walk by Ayi loose I have looked good and I do not see it, someone you give me to tell me where to find information about this problem, I am for buying the palometa set because everything started to clean it. If someone can help me, I will appreciate it
11 years 11 months before - 11 years 11 months before #44547 by manual-mecanica
Manual-Mecanica response on the Picasso 1.8 16V Motor Lost Power Motor failure
Hello Genis149, by dove do you mean to the gase butterfly_, if so, are it electronic or do you have accelerator cable? The other with which they cleaned her. I do not specifically know the model seen pure diesel, but in Citroen benzinero with electronic butterfly, after changing or limpirla you have to do an adaptation procedure of the ECU Motor to the new conditions. If you don't do it, you are likely to generate damage code and may fail. In any case, in my opinion, making a scanner would be the most sensible. Chek Engine may turn on for another reason. greetings.
Last edition: 11 years 11 months before by .
11 years 11 months before #44548 by manual-mecanica
I think the ideal is to take him to the scanner to see with certainty that he is failing.
turbine factories
11 years 11 months before #44661 by manual-mecanica
Hello everyone, I would like to leave this information so that I can serve those who need it, after investigating I bought the body of the butterfly in a scrapping, it cost me to find it finally I found it for € 50 because new searching online the cheapest the cheapest I came out for € 154, in the end I opt for a scrapping, well that I change it 15 minutes and finally solve the problem the problem is no longer cut off and the car is cut off and the car stays. On but no longer fails, I suppose that when it is a little more with the car at the end it will end up going out alone. Well here I leave this comment in case someone helps in the future, to tell you that my Picasso is a 1.8 16V 117CV. Gasoline greeting to all. And thanks for your answers.
11 years 11 months before #44666 by manual-mecanica
Hello Genis149, thank you very much for commenting on the solution, it will surely serve to guide many. The ignition witness, or delete it by making a "butterfly body learning" or disconnecting battery for 15 min., Or the same does the alone ... greetings !!!
