HELP CULATA SEAT IBIZA 1.4 95 ABD
13 years 1 month before #35314 by manual-mecanica
HELP CULATA SEAT IBIZA 1.4 95 ABD PUBLISHED BY MANUAL-MECANICA
Good afternoon
Hello, I am Isaac and I am new
I would need some help to change the Board of the Culata, rather to see if you can guide me and tell me the important steps that I must continue and I must not forget to mount and disassemble the butt and when making the distribution
thank you very much
a greeting a greeting
13 years 1 month before #35318 by manual-mecanica
Manual-Mecanica Answer on the Re: HELP CULATA SEAT IBIZA 1.4 95 ABD
The most important thing about all is the tuning, that is, the draft of the distribution strap, I recommend that you make your own marks so it will be easier to put it later, mark a tooth of the strap with respect to its position on the pulley, you have the same with the distributor, the rest is only logical helps a photographic camera so that you do not forget where the cables and parts that devas you take out.
13 years 1 month before #35324 by manual-mecanica
As Kikemec says you must mark the distribution strap with respect to the toothed pulley, you remove the spark plug cables always marking its position.
To remove the butt bolts you must take them out to the center in the form of a spiral, so you will be sure that you will do it in a good way.
Then you will give the joint and eliminate any reluctant of it.
Then you place the new joint verifying that the holes heat perfectly.
Then you put the butt checking that it is well placed.
Then you put all the butt bolts and press in the Sigante Order.
The squeezes are:
1st tighten stage: 40 nm
2nd Press stage: 60 nm
3rd TIE STAGE: 90 °
4th tighten: 90 °
Then it will be ready.
Then you put the belt in place, verifying that the brands coincide.
Then you turn the crankshaft and verify that the brands coincide again.
In the end, everything covers and put the spark plug cables again in the marked order.
Made to walk and everything ok.
Greetings
13 years 1 month before #35407 by manual-mecanica
If you do not have the tools or the ability to do it because you do not do it that you will create a major problem than you already have.
