Help please I'm desperate
14 years 7 months before #19282 by manual-mecanica
Help please I'm desperate published by Manual-Mecanica
Hi there! I have taken it to several workshops, the Somda Landa has changed, the catalyst was stuck by consumption, we changed it TB following the car with the same symptoms.> Later we cabied the injectors, they checked in the BMW the caudalimetro and put the switchboard in parameters.> The caudalimetro is perfect. The compression of the engine tb is all the cylinders in 10.5 They are fine.
These and desperate since the mechanics do not want to wet with my car because they will change me a lot without knowing if it will be fixed ...
please what can it be ??? The car when the computer is standing on average indicator putting it to zero, when the car is standing, the consumption is triggered only the consumption of the screen is progressively raised in the accelerated screen is continuously going down this continuously ..
can you help me please ???
14 years 7 months before #19289 by manual-mecanica
Manual-Mecanica Answer on the Re: Help please I'm desperate
Hello, this problem in your car is caused by some factors such as the engine's tempera is important to advance it if it controls it or is the question of the spark plugs that are indicated for your car and the air filter unve
14 years 7 months before #19293 by manual-mecanica
Hello, thank you very much for the response, the engine the temperature and progress of time would come out in the machine diagnosis the fault?
I mean that the spark plugs better all original?
14 years 7 months before #19363 by manual-mecanica
Have you put the car to a gas analyzer? Does it have a good time or does it give them high? If so, you have a very high gas mixture and there the high consuno. At the cold in cold it goes well or made black fumes? With the diagnosis they checked the temperature sensor?
14 years 7 months before #19381 by manual-mecanica
Right now I don't know how your car injection system will be but surely carry a system to facilitate cold starting, if this system does not work well and is activated permanently, be it a bypass or a cold starting injector or both the consumption would be high and the reduced power, it would be recommended that you review these systems.
