Water problems in Renault Express
15 years 10 months before #8962 by manual-mecanica
Water problems in Renault Express published by Manual-Mecanica
Greetings to the forum. I have a Renault Express Diesel, and from one day to another, the water throws me back (it comes out by the deposit) without being hot, as soon as I start it. I have removed the thermostat and reviewed the water pump (it seems to be fine) and follow the same thing. Someone can help me? Thank you. Way good the forum.
15 years 10 months before #8963 by manual-mecanica
Manual-Mecanica Response on the Re: Water Problems in Renault Express
Hi, Veni is most likely that you have damaged the cylinder cover joint and you have a compression escape towards the cooling circuit, assuming that you do not have the covered radiator looks there for luck and greetings.
15 years 10 months before #8969 by manual-mecanica
Hi Jal. Thank you the answer. The radiator is fine. And if the cylinders lid joint is the Board of the Culata I do not know what to think, since neither the water has oil nor the oil has water, I think that one of these two symptoms would also have to happen. If it is not so, diminish it please, because then it will be that. Thank you again and greetings.
15 years 10 months before #8972 by manual-mecanica
Veni, according to I understand the water goes out for the escape, if it is in the first time you start it in the day it can be pure condensation of humidity in the cylinders, which is to some extent normal.
If, otherwise the water in any time of the day, if you could have a problem in the custain or creek packing, to verify this I advise you to try with a cylinder leak tester, with this team you can easily detect where the problem is.
I hope it helps you.
15 years 10 months before #8983 by manual-mecanica
Friend If the problem is water in the escape, it is a buttonal together, if the problem is that it votes for the tank check the lid of this, the water in Fuja can pass the oil, or the oil to the water, or only the precion towards the water and there is nothing more than precion has no symptoms, but you can check it taking out the lid of the storage and give it up then to accelerate it if the water sprouts. Cylinders in the water cystem, do not take the thermostat in these systems you cannot equip precions if you do the electros do not leave.
