Codes
13 years 10 months before #24988 by manual-mecanica
Codes posted by Manual-Mecanica
Friends I have a Peugeot 307 placed on the board the engine light placed the Scaner Ida Error Code P0170 and P1336 The mechanic tells me that I have to change the 2 oxygen sensors they were changed but the problem persists now they tell me that I have to change the purge sensor ... Thank you
13 years 10 months before #25003 by manual-mecanica
Manual-Mecanica Response on the Re: Codes
Look at the P1336 refers to the oxygen sensor, but the P0170 makes direct reference to the fuel injection or the mixture of it, erased the memory of the computer after the repair? Czech your injectors and then your tuning, on occasion as in Fiat a tuning rip is reflected as injector failure number 2 luck
13 years 10 months before #25014 by manual-mecanica
If friend erased the code after they installed the oxygen sensor, then it got again and the other one I have noticed I have to have the Full gasoline tank because when the car reaches the car, the car is endured and suddenly the accelerator and still endured it will be that they screwed me in the workshop any other piece? thank you
13 years 10 months before #25015 by manual-mecanica
Hello friend, Mira dile atu mechanical to check canister deposit or also called the pond gas storage because when it covers
13 years 10 months before #25016 by manual-mecanica
Ok thanks, one more question and apologizes my ignorance in the matter that caniester deposit that you tell me is the same as the gas tank
