Nissan Sentra does not recognize any Scaner
13 years 10 months before #24802 by manual-mecanica
Nissan Sentra is not recognized by any Scaner published by Manual-Mecanica
Good evening greetings from Honduras,
I have a Nissan Sentra 2001 engine 1.8 It is my car does not turn on the light of the cock engenie and when putting the scan does not give any error or information, and the problem that I have is that the engine vibrates a lot until it turns off when it is in D. the spark plugs the motor supports the engine the bands the band of gasoline Information ......... I will appreciate your comments
13 years 10 months before #24803 by manual-mecanica
Hello,
if you do not turn on the check Engine, it is very unlikely that you have a recorded error in the ECU, therefore you will never see an error in a scanner
what you can do is a step -by -step motor analysis or IAC, injector review up to probe lambda since it is last sometimes not registered by the computer of your vehicle
13 years 10 months before #24805 by manual-mecanica
Check the spark plug cables may be burned.
13 years 10 months before #24813 by manual-mecanica
Eye What may be happening is that you have problems with the gearbox and when putting it in D lowers the revolutions produces the vibration and then it is covered, upload the revolutions and test if it does the same.
13 years 10 months before #24835 by manual-mecanica
Hello, we have the revolutions upload them and always give the same error, change the spark plugs and the same,
I have not reviewed the gearbox or the spells of the injectors, it will be the problem ,,,,,, there I warn them
SLS
