You are problem with Ford Focus
13 years 10 months before #24286 by manual-mecanica
You are a problem with Ford Focus published by Manual-Mecanica
The vehicle when part stops if you do not keep them accelerated while it is cold, but after it heats there is no problem, the tests of the water temperature sensor is carried out (this model only brings a water sensor that serves for the fan, for the needle, and of temperature sensor) and the IAC but everything went normal
13 years 10 months before #24293 by manual-mecanica
Manual-Mecanica Answer on the Re: You are a problem with Ford Focus
And in high the escape is heard even or does it have interruptions?
13 years 10 months before #24302 by manual-mecanica
Check tested valve, do you feel your brake pedal hard?
13 years 10 months before #24315 by manual-mecanica
In high no problem only in low and that the vehicle and short injection are paired and does not fail, the brake pedal is normal, the IAC also cleaned it ...
13 years 10 months before #24342 by manual-mecanica
Mmmmm is weird how did you check the temperature sensor?
