Identify intermittent intermitters for alarm
13 years 11 months before #23452 by manual-mecanica
Identify intermittent intermittent cables published by Manual-Mecanica
Ola friends I want to put an alarm to my car and I need to save what are the cables of the flashes since I have not been able to locate the same thing happens to me with the centralized celerre if they leave me an electrical scheme I would appreciate it or only the exact indication of the cable
13 years 11 months before #23455 by manual-mecanica
Manual-Mecanica Response on the Re: Identify Intermitter Cables for Alarm
That is depending on the car, but for you to make you easy, you take the current tester you place it to the ground and look for the branch of the crossroads. When you activate it, you place the tester in each branch wire and the one that flickering with the tester found it ..
13 years 11 months before #23469 by manual-mecanica
It is true is the best way since you do not mention even the car you have, but they are usually installed by testing the cables with a test lamp since it is very difficult to tell you this cable is by color code.
13 years 11 months before #23504 by manual-mecanica
Sorry for the lack of information My car is a Peugeot 207 The question is that when it disassembled the bottom of the steering wheel I get only 4 connections with several cables each and none of those cables corresponds to the flashing.
13 years 11 months before #23505 by manual-mecanica
I would also like to identify the centralized closure cables because I put it in the central button and it is not going very well. The centralized locking module is at the door but 5 yellow and green cables come out that are the five same if you can throw a cable
