Honda Accord 92 problem
17 years 4 months before #2321 by manual-mecanica
Honda Accord 92 problem published by Manual-Mecanica
Hello everyone I have a Honda Accord 92 Motor 2.2L The fault is that when the engine comes normal
accelerator
responds sensor and coil and asta is a new head and nothing,
the fault follows there
17 years 4 months before #2325 by manual-mecanica
Manual-Mecanica Answer on the Re: Honda Accord 92 problem
Hello friend, prove this: when the engine starts to fail, remove the fuel tank cap if this corrects the problem, the fuel tank ventilation pipe should be refuted.
If the previous test does not work then testing the distributor igniter
I hope these tests help you
17 years 4 months before #2345 by manual-mecanica
Coco is right, if you have not ignited the \ "Check Engine \" do not look for damaged electronic components, it can be sympleously that the deposit makes you empty when the ventilation is stuck.
Another thing that can give you failures is filter and gasoline pump, but I suppose that having changed pressure regulator checking the circuit pressure was not going too low.
You must also check the airpiration tubes of the car, and vacuum hoses, because it is possible that it is taking air without the switchboard finding out, so that it injected less than normal to the point that it almost stops, when the switchboard detects that the engine turns too slow or that there is a mixture too poor in fuel, injecting sudden Apart from giving a few hell when you circulate with the car.
All the best.
17 years 2 weeks before #3498 by manual-mecanica
Megabeat If all that does not solve it by checking the coil because it usually happens that some are ruined degradly and walk well or more or more or less well in cold but when it heats it begins to fail x a theme in the coil
checks the coil
17 years 1 week before #3509 by manual-mecanica
Check spark plugs, change the temperature sensor, clean the acceleration body and control the fuel pressure, sometimes the sensors are inside the parameters but make values ​​to the switchboard that create those working conditions in the engine if you make you put the computer see well what values ​​it gives you and see if it is among the normal parameters, greetings.-
