Departure in the morning Peugeot Parner
13 years 11 months before #22941 by manual-mecanica
Departure in the morning Peugeot Parner published by Manual-Mecanica
I have a Peugeot Parner year 2001 (Diesel), it has a problem in the game, it is a lot Throughout the day, we have seen it with 2 mechanics and we have good answers, I could help me since I am losing days of work, thanks a million
13 years 11 months before #22964 by manual-mecanica
Manual-Mecanica Answer on the Re: game in the morning Peugeot Parner
You should verify if the spark plug rappe is current and if it comes to do so for a long time, if you want to do a homemade test, put a direct battery cable to the spark plug rapa for about 10 seconds and start it to see what happens, luck
13 years 11 months before #22967 by manual-mecanica
Excuse me ignorance, what is the spark plug rappe
13 years 11 months before #22971 by manual-mecanica
Kikemec wrote: You should verify if current arrives at the spark plug rapa and if it comes to do so for a long time, if you want to do a homemade test, put a direct battery -positive cable to the spark plug rappe
It is Disel Primo, it does not bring spark plugs.
But what should be brought are pre-heater for the initial start of the mornings, maybe there is the failure!
13 years 11 months before #22977 by manual-mecanica
Obviously I mean the ramp of heating spark plugs, look where the candles or incandescent spark plugs are, they connect with each other with a kind of metal laina, which communicate with each other, this one arrives a cable to one of the ends has this where you must reach direct current, if it starts, then it means that the relay of the heater can be failing or that cable Being able to make a repair decision is nothing complicated either from the other world, good luck and avisos us
